Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly. The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
    • Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. Pry the case off using a plastic opening tool. Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo. The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
    • Pry the case off using a plastic opening tool.
    • Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Conclusione
Forrest Lipske
Membro da: 18/01/2013
49 Reputazione
2 Guide realizzate
Cal Poly, Team 19-46, Regan Winter 2013 Membro di Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 213
