Introduzione
Ir your keypad is not working anymore and you want to easily change it at home, use this guide to replace a damaged or malfunctioning LG Chocolate 3 Keypad.
Cosa ti serve
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
Use tweezers to remove the music button found on the side of the phone.
Use the flat end of the spudger to lift the orange display data cable.
To reassemble this device, follow these instructions in reverse order.
