Salta al contenuto principale
LG Chocolate 3 Front Faceplate Replacement
Cosa ti serve
  1. LG Chocolate 3 Front Faceplate Replacement, Front Faceplate: passo 1, immagine 1 di 1
    • Use the plastic opening tool to lift the front faceplate from the device.
    • The faceplate has adhesive in multiple areas. Loosen the faceplate around all of the edges first to make it easier to remove.
  2. LG Chocolate 3 Front Faceplate Replacement: passo 2, immagine 1 di 1
    • The scroll wheel has an orange display data cable attached which may rip from excessive force.
    • Lift the front faceplate up gently.
  3. LG Chocolate 3 Front Faceplate Replacement: passo 3, immagine 1 di 1
    • Be careful not to rip the orange display data cable or drop the scroll wheel on the LCD screen.
    • Use the flat end of the spudger to pry the scroll wheel from the faceplate.
  4. LG Chocolate 3 Front Faceplate Replacement: passo 4, immagine 1 di 2 LG Chocolate 3 Front Faceplate Replacement: passo 4, immagine 2 di 2
    • Separate the front faceplate from the device completely.
Conclusione
Cal Poly, Team 12-35, Amido Spring 2013 Membro di Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 298
