Introduzione
This guide explains how to remove the front plastic screen covering from the phone. This is a fairly simple guide for the LG CU515 SKU 64743 Device. Removing the front screen covering will require only a plastic pry tool. This guide will take you through each step in detail so as to make the process as easy as possible.
Strumenti
Parti
Nessuna parte richiesta.
  1. Carefully pry around the crevice of the entire plastic screen covering using a pry bar or some other type of sharp tool. Be careful when prying as the plastic covering can easily be bent or cracked. Once you have pried all the way around, using tweezers to pull the plastic screen completely off.
    • Carefully pry around the crevice of the entire plastic screen covering using a pry bar or some other type of sharp tool.
      • Be careful when prying as the plastic covering can easily be bent or cracked.
    • Once you have pried all the way around, using tweezers to pull the plastic screen completely off.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
Conclusione
Altre 2 persone hanno completato questa guida.
Maggie
Membro da: 18/10/2013
680 Reputazione
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 289
