Salta al contenuto principale
LG CU515 Front Housing Replacement
Cosa ti serve
  1. LG CU515 Front Housing Replacement, Front Housing: passo 1, immagine 1 di 2 LG CU515 Front Housing Replacement, Front Housing: passo 1, immagine 2 di 2
    • Use an opening tool to remove the thin silver part covering the speaker at the top of the phone.
  2. LG CU515 Front Housing Replacement: passo 2, immagine 1 di 1
    • Remove the four 3 mm Phillips #00 screws.
  3. LG CU515 Front Housing Replacement: passo 3, immagine 1 di 2 LG CU515 Front Housing Replacement: passo 3, immagine 2 di 2
    • Insert the opening tool in the seam between the silver and black parts of the phone casing.
    • Remove the front housing by running the opening tool around the perimeter of the phone.
Conclusione
Cal Poly, Team 21-55, Johann Spring 2013 Membro di Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 425
