Introduzione
This guide will walk you through the steps to remove the motherboard from your LG CU400. It will help remove the battery, the lower half casing, and the actual removal of the motherboard from the phone casing. Before doing this, be aware that you will be unable to use your phone until the replacement is complete. You should also be careful when handling the motherboard because it has delicate wires extending from it.
Cosa ti serve
Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
You should notice that the number pad is loose and can simply be taken out of the open phone casing.
