Introduzione
This guide will show you how to remove and replace the flex cable with a new one. You would only need to replace the flex cable when the screen is white or not displaying properly. This occurs when there is wear and tear on the flex cable.
Cosa ti serve
Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
You should notice that the number pad is loose and can simply be taken out of the open phone casing.
Remove the four rubber covers from the front screen using a metal spudger.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using tweezers, pull the gray plastic piece that is going around the flex cable out of the hinge area.
