Salta al contenuto principale
LG CG225 Keyboard Replacement
Cosa ti serve
  1. LG CG225 Keyboard Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: passo 3, immagine 1 di 1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 1
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Conclusione
Mackenzie
Membro da: 02/13/14
1 Reputazione
2 Guide realizzate
Ohio State, Team 1-3, Meza Spring 2014 Membro di Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 272
