Salta al contenuto principale
LG CG180 Hardshell Case Replacement
Cosa ti serve
  1. LG CG180 Hardshell Case Replacement, Battery: passo 1, immagine 1 di 1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Hardshell Case Replacement: passo 2, immagine 1 di 1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Hardshell Case Replacement: passo 3, immagine 1 di 2 LG CG180 Hardshell Case Replacement: passo 3, immagine 2 di 2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Hardshell Case Replacement: passo 4, immagine 1 di 1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Hardshell Case Replacement: passo 5, immagine 1 di 1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Hardshell Case Replacement, Hardshell Case: passo 6, immagine 1 di 1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Hardshell Case Replacement: passo 7, immagine 1 di 1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Hardshell Case Replacement: passo 8, immagine 1 di 2 LG CG180 Hardshell Case Replacement: passo 8, immagine 2 di 2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Hardshell Case Replacement: passo 9, immagine 1 di 2 LG CG180 Hardshell Case Replacement: passo 9, immagine 2 di 2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Hardshell Case Replacement: passo 10, immagine 1 di 1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Hardshell Case Replacement: passo 11, immagine 1 di 1
    • The hardshell case is separated from the rest of the phone.
Conclusione
Cal Poly, Team 14-42, Regan Winter 2010 Membro di Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,764
