Salta al contenuto principale
LG CF360 Sliding Mechanism Replacement
Cosa ti serve
  1. LG CF360 Sliding Mechanism Replacement, Battery: passo 1, immagine 1 di 2 LG CF360 Sliding Mechanism Replacement, Battery: passo 1, immagine 2 di 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Sliding Mechanism Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery.
  3. LG CF360 Sliding Mechanism Replacement, Back Cover: passo 3, immagine 1 di 2 LG CF360 Sliding Mechanism Replacement, Back Cover: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Sliding Mechanism Replacement: passo 4, immagine 1 di 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Sliding Mechanism Replacement: passo 5, immagine 1 di 3 LG CF360 Sliding Mechanism Replacement: passo 5, immagine 2 di 3 LG CF360 Sliding Mechanism Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Sliding Mechanism Replacement: passo 6, immagine 1 di 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Sliding Mechanism Replacement, Motherboard: passo 7, immagine 1 di 2 LG CF360 Sliding Mechanism Replacement, Motherboard: passo 7, immagine 2 di 2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Sliding Mechanism Replacement: passo 8, immagine 1 di 1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Sliding Mechanism Replacement: passo 9, immagine 1 di 1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 Sliding Mechanism Replacement, Front Case: passo 10, immagine 1 di 1
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 Sliding Mechanism Replacement: passo 11, immagine 1 di 1
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 Sliding Mechanism Replacement: passo 12, immagine 1 di 1
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 Sliding Mechanism Replacement: passo 13, immagine 1 di 1
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 Sliding Mechanism Replacement: passo 14, immagine 1 di 2 LG CF360 Sliding Mechanism Replacement: passo 14, immagine 2 di 2
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 Sliding Mechanism Replacement, Sliding Mechanism: passo 15, immagine 1 di 1
    • Unscrew the eight Phillips #000 (1mm) screws on the back side of where the sliding mechanism is located.
Conclusione
Cal Poly, Team 4-27, Amido Fall 2013 Membro di Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 402
