Introduzione
Your phone uses a spring to help make the keypad slide in and out seamlessly. It is located between the front and back case. In this guide you will learn how to remove and replace this mechanism.
Cosa ti serve
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Remove the two screw covers at the top of phone with tweezers.
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
Unscrew the eight Phillips #000 (1mm) screws on the back side of where the sliding mechanism is located.
