Salta al contenuto principale
LG BP220 Disc Drive Replacement
Cosa ti serve
  1. LG BP220 Disc Drive Replacement, Disc Drive: passo 1, immagine 1 di 2 LG BP220 Disc Drive Replacement, Disc Drive: passo 1, immagine 2 di 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Disc Drive Replacement: passo 2, immagine 1 di 1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  3. LG BP220 Disc Drive Replacement: passo 3, immagine 1 di 3 LG BP220 Disc Drive Replacement: passo 3, immagine 2 di 3 LG BP220 Disc Drive Replacement: passo 3, immagine 3 di 3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  4. LG BP220 Disc Drive Replacement: passo 4, immagine 1 di 2 LG BP220 Disc Drive Replacement: passo 4, immagine 2 di 2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive and pull out to remove.
Conclusione
Altre 5 persone hanno completato questa guida.
Bart Quicho
Membro da: 01/13/15
463 Reputazione
3 Guide realizzate
UW Tacoma, Team 1-1, Rose Winter 2015 Membro di UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 40
Tutti i Tempi: 8,587
