Salta al contenuto principale
LG Aristo MS210 Front and Rear Camera Replacement
Cosa ti serve
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, immagine 1 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, immagine 2 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: passo 1, immagine 3 di 3
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: passo 2, immagine 1 di 2 LG Aristo MS210 Front and Rear Camera Replacement: passo 2, immagine 2 di 2
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, immagine 1 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, immagine 2 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: passo 3, immagine 3 di 3
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: passo 4, immagine 1 di 3 LG Aristo MS210 Front and Rear Camera Replacement: passo 4, immagine 2 di 3 LG Aristo MS210 Front and Rear Camera Replacement: passo 4, immagine 3 di 3
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, immagine 1 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, immagine 2 di 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: passo 5, immagine 3 di 3
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: passo 6, immagine 1 di 3 LG Aristo MS210 Front and Rear Camera Replacement: passo 6, immagine 2 di 3 LG Aristo MS210 Front and Rear Camera Replacement: passo 6, immagine 3 di 3
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: passo 7, immagine 1 di 1
    • Remove both the front and back facing cameras.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 221
