Cosa ti serve
Slide the rear cover downward
Lift it off to access the battery
Locate the small rounded recess to get access to the battery
Gently, lift the battery
Use a Phillips #00 screw driver to remove six screws.
Run the plastic opening tool along the edge of the phone to release the casing cover.
Lift the casing cover.
Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
Altre 2 persone hanno completato questa guida.
