Salta al contenuto principale
LG 305C Speaker Replacement
Cosa ti serve
  1. LG 305C Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Speaker Replacement: passo 2, immagine 1 di 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Speaker Replacement, Internal Casing: passo 3, immagine 1 di 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Speaker Replacement: passo 4, immagine 1 di 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Speaker Replacement: passo 6, immagine 1 di 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  7. LG 305C Speaker Replacement, Speaker: passo 7, immagine 1 di 1
    • Insert plastic opening tool under the plastic flap and lift the speaker out.
Conclusione
IUPUI, Team S6-G1, Baechle Spring 2018 Membro di IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
