Introduzione
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the internal circuit board from the device.
Parti
Nessuna parte richiesta.
  1. Pry open the back case on the device with a plastic opening tool and remove it.
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. Pry the battery out of the device with a plastic opening tool and remove it.
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. Dislodge the microSD card from the microSD card slot using your index finger and remove it.
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  6. Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  7. Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  8. Pry open the top part of the internal casing with the plastic opening tool and remove it.
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  9. Pry the screen from the internal circuit board with a plastic opening tool and remove it.
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
Conclusione
Ashley Kidwell
Membro da: 20/03/2018
427 Reputazione
5 Guide realizzate
IUPUI, Team S6-G1, Baechle Spring 2018 Membro di IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 64
