Salta al contenuto principale
LG 305C Camera Replacement
Cosa ti serve
  1. LG 305C Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Camera Replacement: passo 2, immagine 1 di 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Camera Replacement, MicroSD card: passo 3, immagine 1 di 1
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. LG 305C Camera Replacement, Internal Casing: passo 4, immagine 1 di 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  5. LG 305C Camera Replacement: passo 5, immagine 1 di 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  6. LG 305C Camera Replacement: passo 6, immagine 1 di 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  7. LG 305C Camera Replacement: passo 7, immagine 1 di 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  8. LG 305C Camera Replacement, Motherboard: passo 8, immagine 1 di 1
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
  9. LG 305C Camera Replacement, Camera: passo 9, immagine 1 di 1
    • Pry the camera from the internal circuit board with the plastic opening tool and remove it.
  10. LG 305C Camera Replacement: passo 10, immagine 1 di 1
    • Detach the camera completely by using the spudger tool to poke through the camera attachment holes.
Conclusione
IUPUI, Team S6-G1, Baechle Spring 2018 Membro di IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 141
