Salta al contenuto principale
LG 1010 Front Cover Replacement
Cosa ti serve
  1. LG 1010 Front Cover Replacement, Front  Cover: passo 1, immagine 1 di 2 LG 1010 Front Cover Replacement, Front  Cover: passo 1, immagine 2 di 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: passo 2, immagine 1 di 1
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: passo 3, immagine 1 di 2 LG 1010 Front Cover Replacement: passo 3, immagine 2 di 2
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: passo 4, immagine 1 di 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: passo 5, immagine 1 di 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: passo 6, immagine 1 di 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
Conclusione
Cal Poly, Team 3-25, Regan Fall 2010 Membro di Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,145
