Introduzione
This guide is meant to teach reader to install a new LCD screen. If the current LCD screen is broken or cracked LCD screen, this guide will help the reader to replace it with a new one.
Parti
Nessuna parte richiesta.
Flip the camera over so the bottom is facing you.
  • Flip the camera over so the bottom is facing you.
Aggiungi Commento
Open the cover on the bottom by sliding it in the direction of the arrow.
  • Open the cover on the bottom by sliding it in the direction of the arrow.
Aggiungi Commento
  • Remove the batteries by pulling up on the top with your fingers.
Aggiungi Commento
  • Unless otherwise stated, use a phillips #00 screwdriver to remove screws.
  • Remove the two 4.70mm screws in the bottom of the plastic casing.
Aggiungi Commento
  • Remove the four 4.70mm screws in the left side of the camera.
Aggiungi Commento
  • Now on the side with the strap, remove the other four 4.70mm screws.
Aggiungi Commento
  • Use your thumbs to pry the case apart.
  • It is easiest to pry to case apart if your start at the bottom.
  • The case should come apart with minimal effort. If it doesn't, you can use a tool such as a Spudger or Plastic Opening tool.
Aggiungi Commento
  • This step requires a significant amount of force.
  • Pull the bottom half of the inner camera out of case about half an inch. This may be difficult and force is necessary.
Aggiungi Commento
  • While pulling the camera out of the case, note the small soft plastic cover on the side of the camera. This cover will detach from the rest of the device.
  • Once the bottom of the inner camera is pulled out about an inch and a half, pull the device out completely.
  • When completely removing the device from the case, use a firm grasp with your hands for stability and control.
Aggiungi Commento
  • Turn the camera so that the LCD screen is facing you.
  • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
  • You will not be able to complete this guide without removing the casing completely.
Aggiungi Commento
  • Remove the four 4.40mm screws that hold the LCD screen in place to the frame.
Aggiungi Commento
  • Allow the LCD screen to flip down. This will expose the electric strip connecting the screen to the camera.
Aggiungi Commento
  • Look for where the yellow electric strip is attached to the camera. There is a plastic grey bar and a white base holding this strip in place.
  • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
Aggiungi Commento
  • Unplug the connected red and white wires. They will come out with the small white casing.
Aggiungi Commento
  • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
Aggiungi Commento
  • Remove bottom left LCD mounting frame screw.
  • Remove LCD screen from camera. Screen should come loose after screw is removed. Make sure electric strip comes out with screen.
Aggiungi Commento
Conclusione
Nick Oleskowicz
Membro da: 03/04/2012
236 Reputazione
3 Guide realizzate
Cal Poly, Team 15-13, Forte Spring 2012 Membro di Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,790
