Salta al contenuto principale
LCD LG 37LF65 Capacitor replacement
Cosa ti serve
  1. LCD LG 37LF65 Capacitor replacement, Open the case: passo 1, immagine 1 di 1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: passo 2, immagine 1 di 1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: passo 3, immagine 1 di 1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Conclusione
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
Altre 9 persone hanno completato questa guida.
eugl18
Membro da: 01/18/13
561 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 13,349
