Salta al contenuto principale
Kyvol Cybovac L20 Motherboard Replacement
Cosa ti serve
  1. Kyvol Cybovac L20 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Motherboard Replacement: passo 2, immagine 1 di 2 Kyvol Cybovac L20 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Motherboard Replacement: passo 4, immagine 1 di 2 Kyvol Cybovac L20 Motherboard Replacement: passo 4, immagine 2 di 2
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove 8 screws from the device as shown.
  6. Kyvol Cybovac L20 Motherboard Replacement: passo 6, immagine 1 di 2 Kyvol Cybovac L20 Motherboard Replacement: passo 6, immagine 2 di 2
    • Lift base up and unplug any cable connected form the motherboard into the rest of the components.
  7. Kyvol Cybovac L20 Motherboard Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the 4 screws holding the motherboard in place.
    • Lift the motherboard up and out of the chassis.
Conclusione
ErickAmaya
Membro da: 09/12/23
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 48
