Salta al contenuto principale
Kyvol Cybovac L20 Battery Replacement
Cosa ti serve
  1. Kyvol Cybovac L20 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Battery Replacement: passo 2, immagine 1 di 2 Kyvol Cybovac L20 Battery Replacement: passo 2, immagine 2 di 2
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Battery Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Battery Replacement: passo 4, immagine 1 di 2 Kyvol Cybovac L20 Battery Replacement: passo 4, immagine 2 di 2
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 94
