Salta al contenuto principale
Kyocera QCP-2035 Speaker Replacement
Cosa ti serve
  1. Kyocera QCP-2035 Speaker Replacement, Remove Back Cover: passo 1, immagine 1 di 3 Kyocera QCP-2035 Speaker Replacement, Remove Back Cover: passo 1, immagine 2 di 3 Kyocera QCP-2035 Speaker Replacement, Remove Back Cover: passo 1, immagine 3 di 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Speaker Replacement: passo 2, immagine 1 di 3 Kyocera QCP-2035 Speaker Replacement: passo 2, immagine 2 di 3 Kyocera QCP-2035 Speaker Replacement: passo 2, immagine 3 di 3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Speaker Replacement: passo 3, immagine 1 di 3 Kyocera QCP-2035 Speaker Replacement: passo 3, immagine 2 di 3 Kyocera QCP-2035 Speaker Replacement: passo 3, immagine 3 di 3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Speaker Replacement: passo 4, immagine 1 di 3 Kyocera QCP-2035 Speaker Replacement: passo 4, immagine 2 di 3 Kyocera QCP-2035 Speaker Replacement: passo 4, immagine 3 di 3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Speaker Replacement, Speaker: passo 5, immagine 1 di 3 Kyocera QCP-2035 Speaker Replacement, Speaker: passo 5, immagine 2 di 3 Kyocera QCP-2035 Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • Locate the speaker at the top of the phone right above the screen.
    • Using a spudger or pair of tweezers, gently rock and pry from between the speaker and the main board.
    • There are three plastic tabs holding the speaker, which are located at the back of the speaker.
Conclusione
Jeremiah
Membro da: 01/21/15
122 Reputazione
1 Guida realizzata
USF Tampa, Team 5-3, Brown Winter 2015 Membro di USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 141
