Introduzione
You will learn how to disassemble the phone and remove the speaker safely.
When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
  • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
  • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
  • In 5 mm it will stop sliding.
Aggiungi Commento
Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
  • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
  • Turn the phone over slowly. The battery will fall out on its own.
Aggiungi Commento
  • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
  • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
  • Once the cover starts to part, keep separating until the top notches detach.
Aggiungi Commento
  • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
  • Remove screws.
  • The white plastic face plate lifts right off, exposing the main board.
Aggiungi Commento
  • Locate the speaker at the top of the phone right above the screen.
  • Using a spudger or pair of tweezers, gently rock and pry from between the speaker and the main board.
  • There are three plastic tabs holding the speaker, which are located at the back of the speaker.
Aggiungi Commento
Conclusione
Jeremiah
Membro da: 21/01/2015
122 Reputazione
1 Guida realizzata
USF Tampa, Team 5-3, Brown Winter 2015 Membro di USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 93
