Salta al contenuto principale
Kyocera QCP-2035 Battery Replacement
Cosa ti serve
  1. Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, immagine 1 di 3 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, immagine 2 di 3 Kyocera QCP-2035 Battery Replacement, Removing Back Cover: passo 1, immagine 3 di 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Battery Replacement: passo 2, immagine 1 di 2 Kyocera QCP-2035 Battery Replacement: passo 2, immagine 2 di 2
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
Conclusione
Scott Whitney
Membro da: 01/21/15
301 Reputazione
3 Guide realizzate
USF Tampa, Team 5-3, Brown Winter 2015 Membro di USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 224
