Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Kyocera Oystr, usa il nostro manuale di assistenza.
  1. Kyocera Oystr Teardown, Removing the battery: passo 1, immagine 1 di 3 Kyocera Oystr Teardown, Removing the battery: passo 1, immagine 2 di 3 Kyocera Oystr Teardown, Removing the battery: passo 1, immagine 3 di 3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: passo 2, immagine 1 di 3 Kyocera Oystr Teardown, Removing screws from screen: passo 2, immagine 2 di 3 Kyocera Oystr Teardown, Removing screws from screen: passo 2, immagine 3 di 3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: passo 3, immagine 1 di 3 Kyocera Oystr Teardown, Exposing internal components: passo 3, immagine 2 di 3 Kyocera Oystr Teardown, Exposing internal components: passo 3, immagine 3 di 3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: passo 4, immagine 1 di 1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: passo 5, immagine 1 di 3 Kyocera Oystr Teardown, Screen removal: passo 5, immagine 2 di 3 Kyocera Oystr Teardown, Screen removal: passo 5, immagine 3 di 3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: passo 6, immagine 1 di 1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
Membro da: 10/04/11
24 Reputazione
2 Guide realizzate
UW Stout, Team 5-7, Zhou Fall 2011 Membro di UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Membri
4 Guide realizzate
2 Commenti
where do I get a new screen?
LARS ANDERSEN - Replica
where do i get a new screen
thanks
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,335
