Salta al contenuto principale
Introduzione
Removing the rear casing is simple and easy with the right tools and a little effort. This is also the initial process to access the phone's internal circuitry.
Parti
Nessuna parte specificata.
  1. Wedge the opening device into the side crease of the phone. Wedge the opening device into the side crease of the phone.
    • Wedge the opening device into the side crease of the phone.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
    • Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
  4. Remove the back casing from the front casing. Force may be necessary.
    • Remove the back casing from the front casing. Force may be necessary.
Conclusione
Erica
Membro da: 14/10/2011
101 Reputazione
3 Guide realizzate
James Madison, Team 1-49, Allen Fall 2011 Membro di James Madison, Team 1-49, Allen Fall 2011
JMU-ALLEN-F11S1G49
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 662
