Introduzione
Sometimes the volume button gets stuck and you need to replace it/ fix it. This guide will allow you to do that.
Cosa ti serve
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Once you have taken out the trim, the volume button will be easily removable.
Locate the volume button, if you are looking at the back of the phone (battery side) then it will be on the right side.
Take the tweezers and remove the button.
