Salta al contenuto principale
Kyocera Hydro Vibe Battery Replacement
Cosa ti serve
  1. Kyocera Hydro Vibe Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Battery Replacement: passo 2, immagine 1 di 3 Kyocera Hydro Vibe Battery Replacement: passo 2, immagine 2 di 3 Kyocera Hydro Vibe Battery Replacement: passo 2, immagine 3 di 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,578
