Salta al contenuto principale
Kyocera Hydro Life SD Card Replacement
Cosa ti serve
  1. Kyocera Hydro Life SD Card Replacement, SD Card: passo 1, immagine 1 di 2 Kyocera Hydro Life SD Card Replacement, SD Card: passo 1, immagine 2 di 2
    • Open the back of the phone by prying the back cover off.
  2. Kyocera Hydro Life SD Card Replacement: passo 2, immagine 1 di 2 Kyocera Hydro Life SD Card Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pulling up on the end.
  3. Kyocera Hydro Life SD Card Replacement: passo 3, immagine 1 di 1
    • Remove the SD Card by pushing in slightly and then releasing, allowing the card to slide out slightly and then removing it.
    • Place a new SD Card into this slot, making sure to line up the metal prongs.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 129
