Salta al contenuto principale
Kyocera Hydro Life Rear-Facing Camera Replacement
Cosa ti serve
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, immagine 1 di 1
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, immagine 1 di 3 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, immagine 2 di 3 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 3, immagine 1 di 2 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 3, immagine 2 di 2
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 5, immagine 1 di 2 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 7, immagine 1 di 2 Kyocera Hydro Life Rear-Facing Camera Replacement: passo 7, immagine 2 di 2
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 8, immagine 1 di 1
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: passo 9, immagine 1 di 1
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 205
