Introduzione
The optional microSD memory card expands your phone's available storage so you can save more images, videos, music, documents, and voice data. If you need more storage or if you suspect your card is faulty, follow this guide to swap it out.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Locate the small notch on the bottom right side of the phone.
  • Locate the small notch on the bottom right side of the phone.
  • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
  • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
Aggiungi Commento
Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
  • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
  • The plastic prying tool can be used to help remove the battery.
Aggiungi Commento
  • The SIM card slot can be seen in the middle left of the photograph.
Aggiungi Commento
  • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
  • The gold tipped tines are what read the SD card along its bottom.
Aggiungi Commento
Conclusione
graysonmensah
Membro da: 13/02/2015
22 Reputazione
1 Guida realizzata
Ohio State, Team 1-4, Michaels Spring 2015 Membro di Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
3 Membri
4 Guide realizzate
That's the micro SD slot. That's not for a SIM card.
Carl Jr - Replica
What if there's no metal cover?
Michael ansley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,437
