Salta al contenuto principale
Kyocera Event Ear Piece Speaker Replacement
Cosa ti serve
  1. Kyocera Event Ear Piece Speaker Replacement, Battery: passo 1, immagine 1 di 3 Kyocera Event Ear Piece Speaker Replacement, Battery: passo 1, immagine 2 di 3 Kyocera Event Ear Piece Speaker Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Ear Piece Speaker Replacement: passo 2, immagine 1 di 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: passo 3, immagine 1 di 2 Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: passo 3, immagine 2 di 2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  4. Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: passo 4, immagine 1 di 3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: passo 4, immagine 2 di 3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: passo 4, immagine 3 di 3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
  5. Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: passo 5, immagine 1 di 3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: passo 5, immagine 2 di 3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: passo 5, immagine 3 di 3
    • Soldering required to complete replacement
    • Start by un-attaching the small olive colored chip from the plastic casing.
    • The chip is connected to the phone by a small orange wire. Keep the wire connected to the chip and the phone body while removing the chip from the black plastic casing.
    • Pry underneath the chip with the plastic opener until it pops off. Leave the orange wires attached.
  6. Kyocera Event Ear Piece Speaker Replacement: passo 6, immagine 1 di 3 Kyocera Event Ear Piece Speaker Replacement: passo 6, immagine 2 di 3 Kyocera Event Ear Piece Speaker Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to lift up the black plastic cover.
    • The cover will pop out. Set it aside.
  7. Kyocera Event Ear Piece Speaker Replacement: passo 7, immagine 1 di 3 Kyocera Event Ear Piece Speaker Replacement: passo 7, immagine 2 di 3 Kyocera Event Ear Piece Speaker Replacement: passo 7, immagine 3 di 3
    • Speaker is magnetized.
    • Use a metal object to lift the speaker out OR use tweezers to grab underneath the top corner of the speaker and lift/pry it out.
  8. Kyocera Event Ear Piece Speaker Replacement: passo 8, immagine 1 di 1
    • Unsolder the speaker wires from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
cmiller24
Membro da: 02/13/15
19 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Michaels Spring 2015 Membro di Ohio State, Team 1-2, Michaels Spring 2015
OSU-MICHAELS-S15S1G2
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 864
