Salta al contenuto principale
Kyocera Event Battery Replacement
Cosa ti serve
  1. Kyocera Event Battery Replacement, Battery: passo 1, immagine 1 di 3 Kyocera Event Battery Replacement, Battery: passo 1, immagine 2 di 3 Kyocera Event Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: passo 2, immagine 1 di 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Jen Michaels
Membro da: 08/07/13
22 Reputazione
1 Guida realizzata
Ohio State, Team 1-1, Michaels Fall 2013 Membro di Ohio State, Team 1-1, Michaels Fall 2013
OSU-MICHAELS-F13S1G1
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,147
