Salta al contenuto principale
Kyocera Echo Camera Replacement
Cosa ti serve
  1. Kyocera Echo Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Camera Replacement: passo 2, immagine 1 di 1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Camera Replacement: passo 3, immagine 1 di 1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Camera Replacement, Camera: passo 4, immagine 1 di 1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Camera Replacement: passo 5, immagine 1 di 1
    • Unscrew two 4.8mm Y000 screws.
  6. Kyocera Echo Camera Replacement: passo 6, immagine 1 di 2 Kyocera Echo Camera Replacement: passo 6, immagine 2 di 2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Camera Replacement: passo 7, immagine 1 di 2 Kyocera Echo Camera Replacement: passo 7, immagine 2 di 2
    • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
    • Be careful to not break the circuit board as it is connected to the hinge.
  8. Kyocera Echo Camera Replacement: passo 8, immagine 1 di 1
    • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
  9. Kyocera Echo Camera Replacement: passo 9, immagine 1 di 1
    • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
Conclusione
Alex Kinstedt
Membro da: 11/05/18
483 Reputazione
4 Guide realizzate
IUPUI, Team S2-G6, Baechle Fall 2018 Membro di IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 242
