Salta al contenuto principale
Kurio Xtreme Camera Replacement
Cosa ti serve
  1. Kurio Xtreme Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Camera Replacement: passo 2, immagine 1 di 2 Kurio Xtreme Camera Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Camera Replacement: passo 3, immagine 1 di 3 Kurio Xtreme Camera Replacement: passo 3, immagine 2 di 3 Kurio Xtreme Camera Replacement: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Camera Replacement, Camera: passo 4, immagine 1 di 1
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Kurio Xtreme Camera Replacement: passo 5, immagine 1 di 3 Kurio Xtreme Camera Replacement: passo 5, immagine 2 di 3 Kurio Xtreme Camera Replacement: passo 5, immagine 3 di 3
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Conclusione
Mallory Myers
Membro da: 09/22/15
1.190 Reputazione
7 Guide realizzate
Baylor, Team 6-10, Williams Fall 2015 Membro di Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 178
