Salta al contenuto principale
Kurio Touch 4S Screen Replacement
Cosa ti serve
  1. Kurio Touch 4S Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure to open the back cover easily using the plastic opening tool
  2. Kurio Touch 4S Screen Replacement: passo 2, immagine 1 di 3 Kurio Touch 4S Screen Replacement: passo 2, immagine 2 di 3 Kurio Touch 4S Screen Replacement: passo 2, immagine 3 di 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Screen Replacement: passo 3, immagine 1 di 2 Kurio Touch 4S Screen Replacement: passo 3, immagine 2 di 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  4. Kurio Touch 4S Screen Replacement: passo 4, immagine 1 di 1
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you get them out of order.
  5. Kurio Touch 4S Screen Replacement: passo 5, immagine 1 di 1
    • Remove the plastic cover that is covering the camera area.
  6. Kurio Touch 4S Screen Replacement: passo 6, immagine 1 di 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Screen Replacement: passo 7, immagine 1 di 1
    • Use Phillips # 1 screw to open the 4 screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Screen Replacement: passo 8, immagine 1 di 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Screen Replacement: passo 9, immagine 1 di 1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Screen Replacement: passo 10, immagine 1 di 2 Kurio Touch 4S Screen Replacement: passo 10, immagine 2 di 2
    • Detach all the wire that are connected to the motherboard.
    • Also remove the camera module and other components that are attached to the motherboard.
    • For more information on soldering Click here
  11. Kurio Touch 4S Screen Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Screen Replacement: passo 12, immagine 1 di 1
    • Use the Plastic opener to remove the screen.
    • Do not apply too much pressure as the front cover could be damaged.
  13. Kurio Touch 4S Screen Replacement: passo 13, immagine 1 di 1
    • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  14. Kurio Touch 4S Screen Replacement: passo 14, immagine 1 di 1
    • Use tweezers to remove the screen from your Kurio Toich 4S.
Conclusione
Altre 3 persone hanno completato questa guida.
Ali
Membro da: 01/21/15
184 Reputazione
1 Guida realizzata
USF Tampa, Team 6-5, Brown Winter 2015 Membro di USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,369
