Introduzione
This guide will show you how to replace your front & back camera of your Kurio Touch 4S
Make sure to open the back cover easily using the plastic opening tool.
  • Make sure to open the back cover easily using the plastic opening tool.
Aggiungi Commento
Remove back cover by prying away from the Kurio.
  • Remove back cover by prying away from the Kurio.
  • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
Aggiungi Commento
  • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
Aggiungi Commento
  • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  • All these screws are identical so don't worry if you miss them up.
Aggiungi Commento
  • Remove the battery because it blocks the plastic shield that covers the camera.
  • Do not remove the wires that are attached to the battery and the motherboard.
Aggiungi Commento
  • Remove the plastic cover that is covering the camera area using tweezers.
Aggiungi Commento
  • Separate the two halves of your Kurio Touch 4S.
  • Gently use a brush to remove any dirt or finger prints around the area.
  • Use the Tweezers to detach the front and back camera from its place.
Aggiungi Commento
  • Remove the copper wires by using the Tweezers to replace your new camera.
Aggiungi Commento
Conclusione
Khalid AlTamimi
Membro da: 21/01/2015
251 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Brown Winter 2015 Membro di USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 201
