Introduzione
This guide will show you how to replace your Kurio's battery.
Make sure to open the back cover easily using the plastic opening tool.
  • Make sure to open the back cover easily using the plastic opening tool.
Aggiungi Commento
Remove back cover by prying away from the device.
  • Remove back cover by prying away from the device.
  • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
  • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
Aggiungi Commento
  • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
Aggiungi Commento
  • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
Aggiungi Commento
  • Use the plastic opening tool to remove the battery from its place.
  • The battery is glued into the device. So try removing it gently.
Aggiungi Commento
  • Remove the two wires using soldering tool to detach your bad battery from the device .
  • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
  • For more information on how to solder and desolder the wire Click here
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Khalid AlTamimi
Membro da: 21/01/2015
251 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Brown Winter 2015 Membro di USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Membri
5 Guide realizzate
do you know where to buy a replacement battery ?
Phil Bowring - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,190
