Salta al contenuto principale
Kurio 7 Back Panel Replacement
Cosa ti serve
  1. Kurio 7 Back Panel Replacement, Back Panel: passo 1, immagine 1 di 3 Kurio 7 Back Panel Replacement, Back Panel: passo 1, immagine 2 di 3 Kurio 7 Back Panel Replacement, Back Panel: passo 1, immagine 3 di 3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Back Panel Replacement: passo 2, immagine 1 di 2 Kurio 7 Back Panel Replacement: passo 2, immagine 2 di 2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Back Panel Replacement: passo 3, immagine 1 di 2 Kurio 7 Back Panel Replacement: passo 3, immagine 2 di 2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Back Panel Replacement: passo 4, immagine 1 di 2 Kurio 7 Back Panel Replacement: passo 4, immagine 2 di 2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Conclusione
Replace with a new back panel. To reassemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Eric Rice
Membro da: 04/14/14
913 Reputazione
3 Guide realizzate
Cal Poly, Team 12-36, Maness Spring 2014 Membro di Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,581
