Salta al contenuto principale
Krups F203 Coffee Grinder Trigger Assembly Replacement
Cosa ti serve
  1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: passo 1, immagine 1 di 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 2, immagine 1 di 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 2, immagine 2 di 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 2, immagine 3 di 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 3, immagine 1 di 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 3, immagine 2 di 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: passo 4, immagine 1 di 1
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 5, immagine 1 di 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 5, immagine 2 di 2
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Trigger Assembly Replacement: passo 6, immagine 1 di 1
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
Conclusione
Altre 2 persone hanno completato questa guida.
Ian Hancock
Membro da: 10/22/14
414 Reputazione
3 Guide realizzate
Baylor, Team 4-2, Williams Fall 2014 Membro di Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,435
