Salta al contenuto principale
Krups 963 Power Switch Replacement
Cosa ti serve
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: passo 1, immagine 1 di 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: passo 2, immagine 1 di 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: passo 3, immagine 1 di 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: passo 4, immagine 1 di 1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: passo 5, immagine 1 di 1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Conclusione
Wyatt Hall
Membro da: 10/13/14
842 Reputazione
7 Guide realizzate
Cal Poly, Team 6-25, Maness Fall 2014 Membro di Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Membri
7 Guide realizzate
Un commento
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,040
