Introduzione
The Koosh Vortex Tornado is a ring blaster that was released in 1998. The trigger is the part of the blaster which allows it to fire the projectile, If something is impeding it the blaster may not fire. This is caused by the trigger becoming dislodged from the pin Joint, disconnecting it from the release lever. Please follow these steps on how to fix the trigger.
Make sure that the blaster you have is from Koosh (N/A) and not Buzz Bee (Item #43510). Although they have similarly named products they are very different. Please ensure that the toy is unloaded and not primed as to not have any hazards from projectiles and internal springs.
Cosa ti serve
Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
