Salta al contenuto principale
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, immagine 1 di 2 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, immagine 2 di 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: passo 2, immagine 1 di 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
    Is it correct “insert” the batteries?
    It is not advisable to take them out !
    Any how, I was able to reach the cursor left button, on a Dimage Z5, that is not working. It looks like the problem is on the mechanicall button and not on the switch itself.
    There are small differences, between Z3 and Z5, concerning disassembling, mainly a screw, longer than the others, close to the USB port.
    So, thanks a lot for the help you gave to me.
    Júio
    Joaquim - Replica
Conclusione
Hieu Ngo
Membro da: 03/22/17
431 Reputazione
4 Guide realizzate
Un commento
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 984
