Salta al contenuto principale
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, immagine 1 di 2 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: passo 1, immagine 2 di 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: passo 2, immagine 1 di 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Conclusione
Hieu Ngo
Membro da: 03/22/17
431 Reputazione
4 Guide realizzate
Un commento
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,044
