Salta al contenuto principale
How to replace the Konica Minolta DiMAGE Z3 A/V port
Cosa ti serve
  1. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Open the battery chamber: passo 1, immagine 1 di 2 How to replace  the Konica Minolta DiMAGE Z3 A/V port, Open the battery chamber: passo 1, immagine 2 di 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Insert the batteries: passo 2, immagine 1 di 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove the viewfinder cover: passo 3, immagine 1 di 2 How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove the viewfinder cover: passo 3, immagine 2 di 2
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove viewfinder screws: passo 4, immagine 1 di 1
    • Remove the 2 small screws under the viewfinder.
  5. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove the screen cover: passo 5, immagine 1 di 1
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove screws from the bottom panel: passo 6, immagine 1 di 1
    • Remove 6 screws on the bottom panel.
  7. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Remove screw from battery chamber: passo 7, immagine 1 di 1
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 8, immagine 1 di 1
    • Remove 1 screw inside the battery chamber.
  9. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 9, immagine 1 di 1
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 10, immagine 1 di 1
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 11, immagine 1 di 1
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 12, immagine 1 di 1
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
  13. How to replace  the Konica Minolta DiMAGE Z3 A/V port, Audio/Visual port: passo 13, immagine 1 di 1
    • Remove the single screw that connects the circuit board to the motherboard.
  14. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 14, immagine 1 di 1
    • Carefully remove the circuit board from the motherboard.
    • Leave the wires attached to the circuit board.
  15. How to replace  the Konica Minolta DiMAGE Z3 A/V port: passo 15, immagine 1 di 1
    • The A/V port is glued to the motherboard. Heat should be applied carefully with a heat gun to loosen the adhesive.
    • Remove the A/V port with a spudger.
Conclusione
To reassemble the device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Hieu Ngo
Membro da: 03/22/17
431 Reputazione
4 Guide realizzate
Un commento
Thanks for the help that enabled me to disassembling a Z5.
Is not exactly the same, but helped a lot.
I post comments about the differences I found.
I want only to reack the cursor buttons.
Regards
Joaquim
Joaquim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,027
