Salta al contenuto principale
Konica Compact 8 Front Viewfinder Cleaning
Cosa ti serve
  1. Konica Compact 8 Front Viewfinder Cleaning, Left side screw: passo 1, immagine 1 di 1
    • Remove the screw on the left side if the camera is facing your way.
  2. Konica Compact 8 Front Viewfinder Cleaning, Right side screw: passo 2, immagine 1 di 1
    • Remove the screw on the right side if the camera is facing you.
  3. Konica Compact 8 Front Viewfinder Cleaning: passo 3, immagine 1 di 1
    • Now remove the final screw at the top of the camera. You can now remove the top cover carefully.
    • You can pry the front cover up and down to loosen it. Be careful not to pry horizontally and only vertically. This is because of the open aperture blades that are on the sides.
  4. Konica Compact 8 Front Viewfinder Cleaning, Finish: passo 4, immagine 1 di 1
    • The machinery is now open and can be dissasembled further or the front cover might be cleaned freely without worry that cleaning liquid would seep into the camera.
    • Make sure to remember what the "roll and lock" switch was on before dissassembly or to not touch it at all.
  5. Konica Compact 8 Front Viewfinder Cleaning, Optional: Pushing lever back in place when reassembling: passo 5, immagine 1 di 1
    • You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on.
    • If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
  6. Konica Compact 8 Front Viewfinder Cleaning, Removing the 2 screws: passo 6, immagine 1 di 1
    • 2 flathead screws hold the viewfinder and lightmeter in place.
    • Remove them and then slide the viewfinder out from underneath the upper red wire.
  7. Konica Compact 8 Front Viewfinder Cleaning, Cleaning viewfinder: passo 7, immagine 1 di 1
    • You can now carefully clean both sides of the upper window with a piece of microfibre cloth.
  8. Konica Compact 8 Front Viewfinder Cleaning, Reassembly: passo 8, immagine 1 di 1
    • Reassembling can be done by placing the viewfinder back in place and screwing the screws back in.
    • Start with the bottom, more easily accessable screw.
    • Then do the top, making sure the red wire is between the screw and the higher part of the viewfinder. It can fit just barely.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure the red wire is above the lens and on the right side of the top screw.
JonasB7
Membro da: 11/11/24
485 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 28
