Salta al contenuto principale
Kolcraft Cloud Plus Wheel Replacement
Cosa ti serve
  1. Kolcraft Cloud Plus Wheel Replacement, Wheel: passo 1, immagine 1 di 2 Kolcraft Cloud Plus Wheel Replacement, Wheel: passo 1, immagine 2 di 2
    • Applying too much force to the spudger can cause the spudger to bend or the hubcap to break. To avoid this, try prying the hubcap from a different angle or positioning your spudger at a different points around the hubcap.
    • Use the spaded side of the metal spudger to pry off the small black hubcap on the outside of the rear wheel.
  2. Kolcraft Cloud Plus Wheel Replacement: passo 2, immagine 1 di 2 Kolcraft Cloud Plus Wheel Replacement: passo 2, immagine 2 di 2
    • Pull on the looped end of the cotter pin to remove it.
  3. Kolcraft Cloud Plus Wheel Replacement: passo 3, immagine 1 di 2 Kolcraft Cloud Plus Wheel Replacement: passo 3, immagine 2 di 2
    • Remove the metal washer by sliding it off the axle.
  4. Kolcraft Cloud Plus Wheel Replacement: passo 4, immagine 1 di 1
    • Slide the wheel off of the axle.
Conclusione
Cal Poly, Team 11-1, Forte Fall 2015 Membro di Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 39
Tutti i Tempi: 4,267
