Salta al contenuto principale
Kolcraft Cloud Plus Seat Replacement
Cosa ti serve
  1. Kolcraft Cloud Plus Seat Replacement, Seat: passo 1, immagine 1 di 3 Kolcraft Cloud Plus Seat Replacement, Seat: passo 1, immagine 2 di 3 Kolcraft Cloud Plus Seat Replacement, Seat: passo 1, immagine 3 di 3
    • Unsnap the six buttons holding the storage basket under the seat.
  2. Kolcraft Cloud Plus Seat Replacement: passo 2, immagine 1 di 1
    • Unsnap the ā€œChild Trayā€ by pulling outwards on the plastic connectors on either side of the stroller. As you pull, lift upwards to completely remove the tray from its connection to the strollerā€™s frame.
  3. Kolcraft Cloud Plus Seat Replacement: passo 3, immagine 1 di 1
    • Remove the "Parent Tray" by pulling outwards on the plastic connectors on either side of the stroller. Lift straight up to remove completely.
  4. Kolcraft Cloud Plus Seat Replacement: passo 4, immagine 1 di 3 Kolcraft Cloud Plus Seat Replacement: passo 4, immagine 2 di 3 Kolcraft Cloud Plus Seat Replacement: passo 4, immagine 3 di 3
    • Unscrew the three, 14mm Phillips #2 screws on the outer frame of the stroller and repeat for the opposite side.
    • Remove the plastic washers that come off with the screws.
    • You may have to fold the stroller, then flip it over to access the screws on its underside.
  5. Kolcraft Cloud Plus Seat Replacement: passo 5, immagine 1 di 1
    • Unscrew the two, 14mm Phillips #2 screws on either side of the outside frame near the foot rest.
    • Remove the plastic washers.
  6. Kolcraft Cloud Plus Seat Replacement: passo 6, immagine 1 di 1
    • Unscrew the two, 14mm Phillips #2 on the underside of the seat and repeat for the opposite side of the stroller.
  7. Kolcraft Cloud Plus Seat Replacement: passo 7, immagine 1 di 2 Kolcraft Cloud Plus Seat Replacement: passo 7, immagine 2 di 2
    • Unscrew 14mm Phillips #2 screw on the underside of the stroller and repeat this process for the opposite side.
    • These plastic washers are circular to better fit around the frame. Remember that these locations require the circular washers.
  8. Kolcraft Cloud Plus Seat Replacement: passo 8, immagine 1 di 1
    • Pull the cover down the metal frame to reveal a 14mm Phillips #2 screw on either side of the inside frame.
  9. Kolcraft Cloud Plus Seat Replacement: passo 9, immagine 1 di 1
    • Unscrew the 14mm Phillips #2 screws located under the cover on either side of the inside frame.
  10. Kolcraft Cloud Plus Seat Replacement: passo 10, immagine 1 di 3 Kolcraft Cloud Plus Seat Replacement: passo 10, immagine 2 di 3 Kolcraft Cloud Plus Seat Replacement: passo 10, immagine 3 di 3
    • Using the spudger, pop out the small, white ball that's on the underside of the plastic part of the frame. Repeat this process for the opposite side.
    • Brace the spudger against the frameā€”it will provide the extra force needed to pop the white balls through their holes.
  11. Kolcraft Cloud Plus Seat Replacement: passo 11, immagine 1 di 2 Kolcraft Cloud Plus Seat Replacement: passo 11, immagine 2 di 2
    • Place the metal spudger between the plastic connector and the metal frame of the sun shade.
    • Use the spudger to pry outwards on the plastic while simultaneously pulling straight up on the metal frame of the sun shade.
    • Repeat this process for the opposite side to completely remove the seat.
    • Use one hand to brace the frame of the stroller by firmly pushing down on the plastic part of the frame.
Conclusione
Cal Poly, Team 11-1, Forte Fall 2015 Membro di Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,702
