Salta al contenuto principale
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Cosa ti serve
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: passo 1, immagine 1 di 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: passo 1, immagine 2 di 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 2, immagine 1 di 1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 3, immagine 1 di 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: passo 4, immagine 1 di 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Conclusione
Cal Poly, Team 11-1, Forte Fall 2015 Membro di Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,296
